KittchenAid KBFN402EPA01 French Door Built-In Refrigerator - Some LEDs not working
TrippKnightly
mill valley, CA
KBFN402EPA01
As above. 5 years old, pretty good refrigerator, but entropy wins in the end. There are one (maybe two) freezer lights out and then two top / ceiling lights also out. 2 pairs of 3 sidewall LEDs in refrigerator compartment are lighting. Prior discussions suggest the refrigerator LEDs (some at least) have dependency on the freezer lights, even though they have different switches. So it's possible I don't 3-4 LEDs all failed (LEDs, no less!!). And apparently "right to repair" is only taking off so I can expect real difficulty in removing the freezer LEDs and attaching new. (The wiring diagram vis a vis the lights disagrees with itself as well as what's truly in the unit, naturally.)
Any other later-breaking input?
Hi Tripp,
Yes, replace the Freezer LED Light Module and the remainder in the refrigerator section will start working too.
Here's the Freezer LED Light Module for your model you can order: W11462342
This video gives you the general idea of how to replace it:
