KMBS104ESS03 KitchenAid Microwave - Control Panel
ronipowell
Alexandria LA
KMBS104ESS03
Part of the LCD display on my microwave is out, making it very difficult to read the numbers. In addition, several of the touch pads left of the display, such as defrost, do not work. I have unplugged the unit, and the display will briefly reset and work, but soon goes back as it was. Is there something I can replace to fix this problem? Regular timed cooking using the dial works fine; it’s just hard to see how much time is on the display.
Your model does have a user interface and separate user interface board. You may want a local pro to come take a look.
