KMHS120ESS1 Kitchenaid Microwave door -- if pulled downward turns on
F1Rocket
SSI
KMHS120ESS1
If slight downward pressure is made on handle when opening, the microwave turns on. The light, the fan, but not the turntable. I see no fault codes on the screen. The only way to stop the microwave is to open the door and reclose it. Pushing the "cancel" will not stop the microwave. I don't know if it is actually heating....didn't want to chance having a problem due to nothing being inside on the turntable.
Added complete model number
G
Guest
Guest
Last portion of the model # is needed
One of the door switches is bad. There is a interlock switch update. Call KA for safety issue
Place a damp paper towel and close door for about 10 seconds. If it's warm after the magnetron is running
