KMHS120ESS4 Door error
1933beer
CB Iowa
KMHS120ESS
Model KMHS120ESS4 microwave manufactured in 2016. I purchased this in 2017 and about 6 months after I installed it this issue started. It was intermittent until yesterday. I can get the thing to clear the meaasge. I think it I a microswitch in the door. I read some posts that say I may need to adjust or replace them. How do i adjust them? If I need parts where could I get the parts diagram so I order the correct parts.
The latch bracket assembly holds the microswitches. On some models it's adjustable but not all models. To check the door switches Unplug microwave oven or disconnect power.
Remove the air grille
Open the microwave oven door and remove the control panel assembly
From here you should be able to access the microswitches. Remove the wires from the microswitches and check them for continuity by opening and closing the door.
Here's the three door switches:
W10727360 Switch
W10269460 Switch
W10269458 Switch
