KMHS120ESS7 KitchenAid over range microwave Bulb glued in?
jcz
New York
KMHS120ESS7
Hello. I have a roughly 3 year old KitchenAid over range microwave. The range light won’t turn on. I removed the cover, inspected the bulb. When touching the bulb it turns on. Stays on for a day or so (turning on and off) then won’t turn back on. If I remove the cover and touch the bulb, it will come back on.
Seems like a loose connection or a dying bulb. But there is the enigma: the bulb seems to be “glued in” with a clear silicon type of glue. I cannot remove the bulb because of the glue.
Any thoughts? Your help is appreciated. Thanks.
It does sound like a loose connection. The bulb and socket are separate parts.
LINK > KMHS120ESS7 Bulb/Socket
Maybe the socket got melted to the bulb from the heat generated by a loose connection? You'll probably have to get a closer look.
