KOCE500ESS01 KicthenAid microwave/oven- microwave works only when hold the door tight
jjohn2
California
KOCE500ESS01
When push Start button microwave it will not start!!.. It works when we hold the door tight..
For the microwave to work- Need to hold the door tight always!
I noticed that right side of the microwave door (bottom hinge) is lightly loose and saw one of the pin of the hood hinge is misaligned.
I was told the replacing the Door hinge may help..but the problem is that door hinge for this model is not available anywhere!!!..
part # WPW10510097
It there any alternate part or repair items for this model; / other tips for repair are highly appreciated!!
Thank you in advance
No, I meant what number is it in the parts diagram I posted the link to above in post #2?
