FIXED KRFC704FPS KitchenAid fridge RC evaporator completely iced up
jc00ke
Portland, OR
KRFC704FPS
Hi all,
First, this forum is the absolute best place to find debug info on appliances, so thank you to everyone that makes that happen.
A few months ago we noticed water in the basement under our fridge but didn't connect the issue to the fridge until the RC warmed up. I pulled the shelves out and thawed the RC evaporator, which was completely iced up. A big block of ice. Here's a non-exhaustive list of debug steps I've taken:
  • ran through diagnostics, no SH or OP. Temps all seemed OK.
  • checked that the thermistor was in the correct spot according to other posts on the forum (it was)
  • tested the resistance on the thermistor, 7.6kΩ at 40°F and 8.2kΩ at 35°F
  • tried to test the evaporator fan DC voltage but was unable to (not sure *exactly* how to do this, tried to follow the advice in a post here)
The latest rev of the control board is being shipped right now but I'm not sold on swapping it out quite yet.
I plugged everything back in and ran the fridge for 2 days, then pulled the evaporator cover off to check things out and there was already some ice buildup. The black foam pad on the inside of the Styrofoam cover was saturated with water. Culprits I can think of:
  • sync motor isn't opening the damper
  • evaporator fan is bad (sometimes something makes a little noise but it might be the damper opening, not sure)
  • compressor issue
  • bad control board
Any other ideas? Thanks for helping me troubleshoot this! I'll be happy to provide more info if needed.
Jesse
Keep both “—” and “—” temperature buttons pressed for 3 seconds. Countdown will display and a chime will play upon entry into Service mode.
Enter Key = “Drawer” button
Increment Key = “+” button on the upper display
Decrement Key = “-“ button on the upper display
Back Key = “Max Cool” button
To Exit Service diagnostics, use “Max Cool” Key to back out of functional test. Press and hold “-” and “-” temperature buttons simultaneously for 3 seconds.
Service Test #00 Exit Service Mode:
This step is an alternative method to exit service mode and return to Normal Operation.
Service Test #57 RC Fan Test
When entering this service test, the Refrigerator Compartment fan turns on. The display shows “ON.” When leaving this service test, the refrigerator fan turns off.
jc00ke
Portland, OR
Thanks Rick!
Service Test #57 RC Fan Test: fan turned right on!
I should clarify, I wasn't able to test the voltage across the fan, but I guess I didn't need to.
Is the frost pattern on the evaporator partial or on all the coils? You probably noticed the evaporator is black. That's because it doesn't use a defrost heater. When the FF compartment is calling for cooling the control checks the thermistor before the compressor turns on. If the control suspects the temp is too cold and there's frost on the coils, it will turn the FF fan on for up to 10 minutes (to ensure the coils are defrosted) before starting the compressor. Make sure there are no air leaks around the cover and check the foam seal is in place.
jc00ke
Portland, OR
I believe it was partial. I checked the seal and it looks fine. It didn't look like there were any gaps between the cover and the back of the fridge, but it's kinda hard to tell.
I had to put the food back in. What would my next steps be to debug this? Thanks again for your help!
Leave the machine plugged in and running, remove the cover, take a pic of the coils and post it here. Does the refrigerator cycle off and on or does it run continuously.
jc00ke
Portland, OR
I jumped the gun on putting everything back. I'll have to wait until Friday or next weekend to take it apart again, then will post pics.
jc00ke
Portland, OR
It seems like it runs continuously, but it's so quiet that is hard to tell when it's in the cabinets. Is there another way to tell?
jc00ke
Portland, OR
What's the timeline on checking things again? Should I give it a month? Is there a way to keep an eye on things without having to pull the fridge apart? Thanks!
jc00ke
Portland, OR
Well, just as we were about to walk out the door to go camping for 2 nights, we saw a small puddle. I ripped the fridge apart and the right half of the RC evaporator was iced up.
AM-JKLVV4KuK5UPYYsbiP1NzLCtBfD3PWctf40WN2JXFGKpGKz4-cVP0LwZo6ZLD2e_4g6E63RjzD5p5b74NuWkTbmXMo4NiMnaSrb2wFFFhwieQfpciPlcdZtFR5U4gZVDuzLk2ZBf8QzGPNKtDxiR4lpS8fw=w952-h714-no
I'm not sure what to do now besides either replace the control board (which we have the latest compatible model already here, I was avoiding taking it out of the box) or call in service. Ideas? Thanks!
jc00ke
Portland, OR
I defrosted the RC evaporator coil, plugged everything back in and turned it on... water started dripping:
It was probably 1/4 cup, but pretty soon after plugging it back in. I've turned the water supply & ice maker off just in case.
I also took the back panel off but could not see any evidence of water (I'm guessing that's the FC evaporator anyway)
