I think this is the same as yours. Switch numbers:
To Enter Service Diagnostics Mode:
NOTE: Refrigerator must not be in lockout mode prior to entering Service Diagnostic mode.
1. Press SW1 and SW2 simultaneously for 3 seconds.
2. Release both buttons when you hear the CHIME indicator. The display will show “01” to indicate the control is in Step 1 of the diagnostics routine.
Each step must be manually advanced.
Press SW5 to move to the next step in the sequence.
Press SW4 to back up in the sequence to the previous step.
Service Test - 56: Ice Maker Error Codes
Displays active ice maker error codes on the UI display.
E0 = No errors. Functioning ice maker.
E1 = No cooling. Ice maker timed out. Ice compartment unable to reach desired temperatures. Possible cooling or fan issue.
E2 = Motor lost position. Ice maker did not find home during harvest and exceeded maximum attempts.
NOTE: Check for obstructions in ice maker. If none found, verify operation of the ice maker with Service Test 57.
E3 = Heater time-out, Ice mold heater was on longer than maximum allowable time. Ice maker heater is driven to a temperature. If temperatures not reached, a time delay shuts it down. Possible heater issue.
E4 = Dry cycle. Unit detected dry cycles above minimum requirement. Possible valve or frozen tube.
E5 = Bad ice maker thermistor, Ice storage temperature satisfied but ice mold in frozen state too long. Possible ice mold thermistor issue.
Service Test - 57: Ice Maker Harvest
Press
SW3 to activate a harvest sequence.
NOTE: Digit 1 displays the state of the sequence. Digit 2 displays the outcome of the sequence. Once initiated, the sequence cannot be exited.
Digit 1 (0 = heater and motor off, 1 = ice maker heater on, 2 = motor rotating clockwise until it finds home position)
Digit 2 (0 = in progress, 1 = harvesting completed, 2 = harvesting not completed). Doors must be closed.
NOTE: “Harvesting not completed” does not exit the step, but indicates the time-out of 70 seconds has passed.
Service Test - 58: Ice Maker Heater Activation and Thermistor
Press
SW3 to activate the ice maker heater and to toggle between on and off.
NOTE: Digit 1 displays the state of the heater. Digit 2 displays the thermistor state.
Digit 1 (0 = ice maker heater off, 1 = ice maker heater on)
Digit 2 (0 = temperature warmer than harvest temperature, 1 = temperature cooler than harvest temperature, 2 = open, 3 = short)
Service Test - 59: Ice Maker Motor
Press
SW3 to activate a motor sequence and toggle through each step.
NOTE: Digit 1 displays the state of the motor. Digit 2 displays the status of the motor. Once initiated, the sequence cannot be exited.
Digit 1 (0 = motor off, 1 = motor rotating clockwise until home position, 2 = motor off, 3 = motor rotating counterclockwise until home position)
