KRFC704FPS00 KitchenAid not making ice cubes
Icpindy
Indianapolis
KRFC704FPS00
Hello all, my refrigerator is literally 2 weeks out of warranty and now it decides it wants to stop making ice lol, the ref is getting water and dispenses through the front, the auger is turning, I tried to put it in test mode and run 97’ and i hear it kick on but it doesn’t put water into the tray, I’m. It sure what else to try. Any help would be greatly appreciated. Model KRFC704FPS00
Added complete model number
Your missing two digits after the "S" at the end, we would need those. The model number tag is located inside the refrigerator section on the upper walls or ceiling.
Here's the results I get:
KRFC704FPS00
KRFC704FPS01
KRFC704FPS03
I'm attaching your tech data sheet below.
When you have it in TEST 97 take a voltage reading between P3-3 and P1-2 on the main control board and tell us how many volts you get.
The main control board is on the back of your refrigerator.
Control Board W11333076
Icpindy
Indianapolis
I am at work right now I’ll do that later today or tomorrow, when I ran that test last night I heard something come on then the display showed PP
Ok, let us know what you find.
What came on? I don't see "PP" listed anywhere in your tech data sheet.
Ok, I don't know then, all we can do now is the voltage test.
Ok, sounds good, keep us posted.
