FIXED KRFC704FPS00 KitchenAid Refrigerator not cooling properly
Kowens
Lawrence Ks
Foam cover was stuck to the evaporator....
Guess I need the cover with gasket and might as well replace the thermistor while I’m there.
is the new cover made of styrofoam and have the gasket attached?
Yes you get everything when you order the evaporator cover:
Also look on page 6 of that service bulletin I posted--->Check the Refrigerator section evaporator thermistor for proper contact with the tubing.
Kowens
Lawrence Ks
Got it sir, I assume the thermistor is placed in the linear part of the tube and not on the curve.
sure hope this fixes it
Yes, that is correct, per the photo you see of it in that service bulletin.
Kowens
Lawrence Ks
Hi Jake,
Got the evap cover in yesterday and installed. The unit had thermistor fan and pantry diverter as well as an upgraded gasket and pad that rests against the evap.
everything has checked out fine this morning!!!!!!
i suppose the main board replacement coupled with the evap/thermistor replacement did the trick.
of notwhen going through this I found
1. Condenser air inlet blocked with dust/dirt
2. Main board at rev 4.0.0. (Needed 6.0.0)
3. Evap froze solid
4. Evap thermistor located a bit up the tube ( lowered on reinstall)
Thanks again for all the support !!!!!
Best Regards
Ken
Excellent Ken, glad to hear your back in business.(y)
