KRFF302EBS00 Strange burp noise from KitchenAid frig. Recordings attached.
grubbyfingers
WI
KRFF302EBS00
After about 3 years the frig started making a short burst of noise once near the beginning of each cycle.
I have attached 2 recordings of the noise. The recorder was placed in the refrigerator near the damper control as I thought that might be the source of the noise, but the noise seems to occur several seconds after the damper has stopped moving.
The first recording is a loop playing the same noise over, 4 times in a row.
The second recording is a recording of the start of a cycle. First the damper door exercises itself, then about 5 seconds of silent and then the mystery burp!
The burp noise is just as loud inside the frig as outside the frig. The damper motor is not heard outside the frig.
It sounds like your air damper motor is broken/stripped and making that noise.
Here's the air damper assembly for your model you can order:
WPW10594329 Control
Watch this video to replace it:
grubbyfingers
WI
I have watched the air damper go through it's routine from full closed to full open and back again, and it doesn't make the noise then. I have never been able to watch the damper while the noise occurs as it only happens a few times a day.
I will try to catch it in action.
I have also put the recorder in the (bottom) freezer compartment and the noise is audible down there too, but the noise of the normal damper movement is not.
Ok, yes its very important to pinpoint that noise, to me it sounds like the damper going bad.
