KRFF302ESS03 KitchenAid Refrigerator Water dispenser not working
dieselgg
KRFF302ESS03
I have Kitchen-Aid refrigerator model: KRFF302ESS03 (French doors) Canadian model. Earlier today, the water dispenser was working, but just now when I pressed the button, all I hear is a buzzing sound, and no water coming out. I use an official kitchen-aid water filter and it is about 4 months old.
I removed the water filter from the pull-down housing and pressed the two buttons located in the back of the water filter housing and water sprayed out with ample pressure. I then reinserted the water filter and now the water dispenser works again. There was no slurry sound when I pressed the button. Just the sound of water coming out with air pockets. What do you think happened?
Perhaps unrelated but back in Feb, I heard to turn the temp up one notch in the refrigerator as I was would hear a slurry sound. https://www.applianceblog.com/mainf...-few-secs-hear-slush-sound.95326/#post-493367
Regards,
Gus
Hi Jake,
Yes, it is working now. It only took a few seconds to purge the air gaps.
If it happens again, then I will take the route of replacing the water filter head.
Thank you,
Gus
Ok Gus, sounds like a plan.:)
