FIXED KRFF707ESS01 KitchenAid Refrigerator Not making ice
dannydy
USA
KRFF707ESS01
My KitchenAid Refrigerator Not making ice after have to defrost and replace the evaporator fan.... I did all the checks and very thing pass but notice inside the ice bin its 30 degree where the ice sits.. I need so help or directions...
Which evaporator fan motor did you replace? The one in the freezer? Or the one in the refrigerator section?
You will need to give it up 72 hours to start making ice after you defrosted the evaporator coil and replaced the evaporator fan motor.
Put the thermometer in the freezer section and tell us what it reads in 2 hours.
28 degrees? That's way too warm, needs to be less than 10 degrees to make ice.
Do you hear the freezer(evaporator) fan motor running in the freezer?
Do you see frost build-up on the back panel inside the freezer?
If so do--->Service Test - 6: Defrost Heater/Bi-Metal
NOTE: If bi-metal is open, it will need to be bypassed for heater to operate.
Heater should be ON. Display will be blank until a valid reading is displayed (01 = bi-metal closed, 02 = bi-metal open).
I'm attaching the data sheet below that shows you how to enter diagnostics to do that.
  • W10832298-RevA.pdf
dannydy
USA
There is no build up of frost or anything.... What is next area to look at..
If the freezer fan motor is running, and no frost build-up then you have a sealed system problem and you will need to have KitchenAid come out under your 5 year parts and labor warranty on the sealed system.
I'm attaching your warranty sheet below.
  • warranty-W10859998-W.pdf
Glad to help Danny!
dannydy
USA
Jake you was correct.... Kitchenaid tech stop by and said yes you have leak and cover by warranty... but the parts are out stock...
Glad to hear that Danny, let us know how it goes when the parts become in-stock again and when the KitchenAid tech comes back out to fix it for you under warranty,
dannydy
USA
its all fix and making ice and keeping everything cold..
Thank you jake!!
Excellent Danny, glad to hear the KitchenAid tech. fixed it for you, and now you have good cooling and good ice making.(y)
