FIXED KRMF606ESS01 KitchenAid Refrigerator - Pantry Drawer User Interface & Water do not work. Ice does work
kodiwan
KRMF606ESS01
Just yesterday the water dispenser quit working on our KRMF606ESS01 KitchenAid Refrigerator. At first the LED lights and the dispenser didn't work and the Code UAC was being displayed. I performed some troubleshooting getting into the service codes and some features began working again. Later i realized the Pantry Drawer User interface was not working so I tried unplugging the harness from both the back of the door and the user interface.
At the moment the ice maker still works and dispenses, but the water will not dispense. The water will dispense in service mode 46. The Pantry Drawer User Interface is still not working. Trying to figure out if its the wiring harness or the Aurora Board. Any help greatly appreciated. Thanks!
Check for 14 volts DC at the wire harness electrical connector that connects to the Pantry UI Board.
Here the Pantry UI Board for your model:
User Control and Display Board WPW10769076
Its in-stock here: WPW10769076
Service Test - 46 Water dispensing Test--->Displays the status of the water dispense valve. Press the water pad to initiate a water dispense. (00 = Water Dispense Valve Off, 01 = Water Dispense Valve On).
On the main control board volt test at P3-4(violet wire) to P1-2(white/black wire) should be 120Volts AC Output to Water Valve when Water dispensing, when the water dispenser paddle is pressed and the door closed.
  • W10844356-RevA.pdf
Thanks for the info. I tested for 14Vdc at the connectors shown in the picture. I did not get any voltage reading. Do you know which are ground and which are power? I tried the blue and brown on the one connector and then a combination on the other. No luck.
Regarding the service 46. This does activate the water dispenser and it works.
I have not yet tested the control panel in the rear.
J1A-1 is the tan wire J1A-4 is the orange wire, between those two you should have 14 volts DC.
Alrighty... I do NOT have 14Vdc between J1A-1 and J1A-4.
I traced those wires in the diagram and there is 12Vdc @ Main Board P2-1 and P2-7 and also at the Power Supply P6-1 & P6-2. So it seem power is not getting to the Pantry Board.
Also, for some miraculous reason the Water Dispenser has started working again since messing with the wires in the back panel..
Guess next step would be to pull the wire hardness of the pantry door and Ohm it out?
Yes, exactly.
Here's the wire harness to it:
Pantry Drawer Wire Harness W11170612
Here's the video to access it:
Thanks! After reviewing the video, made the decision to just order the harness and swap it out. Will let you know the results.
Ok, sounds good, yes keep us posted.
Excellent good job, glad to hear that.(y)
