KRMF606ESS01 LED lights dim and some bright
kcutter
KRMF606ESS01
Quick Question: I am having the same problem all the lights on my roof are dimmed and the lights the sides are bright. Would this been a control board issue or is one of the individual lights causing the problem. My model number is
KRMF606ESS01. Thanks for the help
Is the freezer LED out or dim too?
Usually It's not that board in the back that's the problem, I have come to find out.
These LED lights run in series(like the old Christmas lights, if one goes out or dim they all go out or dim), if the freezer LED goes out or dim it makes the TOP LED's in the refrigerator either go dim or completely out.
Replace the Freezer LED module and it will also fix the TOP LED's in the refrigerator section.
Here's the freezer LED module for model number you can order:
Light Assembly W11205083
Video Included in part link.
kcutter
Thanks for the help. The Freezer light is out. I will order the light assembly to replace it.
KC
Ok great KC, then the new freezer LED I posted the link to above will fix your other LED's in your refrigerator section.:)
