- KRMF606ESS01
- KitchenAid
- 1-5 years
Hello. Long time listener, first time caller. I'be been having an issue where there is water dripping from what I think is my Ice Bin and pooling up. I've read through several posts here but so far no luck. I just replaced the Ice Door per this thread but it didn't help.
I've run all the diagnostic tests I could find across multiple threads and everything appears to be OK. No issue with any thermistors or ice maker. It's been driving me crazy. I also checked the water reservoir after doing a fill test. No leak there. Not sure if it's related, but my fridge is set to 33F and my interior standalone fridge thermometer shows about 37-40F.
I had a KitchenAid certified company come out and they said the temp is with normal range. My only thought is that the ice isn't cold enough and it's melting a little? The temp variance doesn't bother me but the pooling water is driving my wife and I nuts. I can't tell if it's coming out the weep hole or elsewhere. I'm going to tape a paper tower over the whole to see if it catches water or if the water is leaking from where the ice drops out or the maker.
