fridgeman69
- KRMF706ESS01
- KitchenAid
- 1-5 years
Howdy. I can't seem to figure out why, but my KRMF706ESS01 fridge compartment is not consistently at temp. It seems like every couple of days it can't cool below 55ish degrees, but then it will suddenly go back to keeping the temp below 40 (as it should) for a day or two. No amount of "resetting" the control board (power cycling and/or power off for 1+ hour then powering back on) fixes anything. A tech replaced a bad thermistor last year and made sure to put the new one in the correct location (per the attached service bulletin), so it shouldn't be that issue.
I have two known issues but I don't see how either would be the culprit:
Possibly a coincidence, but today I soaked up the tiny bit of water in the produce compartment, and as I was doing so the compressor and fans kicked on. They then stayed on until the fridge reached the desired temp. Usually, on days the fridge isn't working correctly, the compressor will kick on but then turn off a short amount of time later, while the fans will stay on for hours at a time.
- The evaporator drain pan (in the produce compartment) is bowed in the middle a little bit. I do have some water in the produce drawer compartment as a result, although it's not much. A month ago I had to clear a large amount of water out but I assumed that water had come from the ice maker, which I've since shut off completely (no sense in making ice that just melts right away). Clearing said amount of water fixed the fridge for about a week. The problem then returned, despite there being zero or very little amounts of water present again.
- The pantry door control panel wires are not connected to anything. When the tech replaced the thermistor last year they did something to pull the wires out. See attached picture; based on the wires being clean cut I don't see how to possibly reconnect them. Regardless, I have no idea if this matters at all; I personally don't care what setting the produce drawer is set to. I only care if it being disconnected is somehow causing the inconsistent cooling issue.
