KRMF706ESS01 Kitchen aid refrigerator Water Dispenser works in DIAGNOSTIC mode testing only
ed_texan
Texas
KRMF706ESS01
Power outage occurred in my neighborhood due to storm. P.F. indicated on front control panel.
1. Checked operation….freezer cold working. Refrigerator cool inside.
2. Checked water dispenser—did not work. Ice dispenser and everything else works.
3. Diagnostic testing. Ran test 46 for water dispenser. WORKS as expected and dispenses water. Will NOT dispense water in normal operation/mode.
Initially thought water reservoir frozen, but running diagnostic disproved that. Reset power to refrigerator hoping a simple reset would allow unit to come back to normal status. NO JOY!
Before I open her up, any ideas?
Thanks in advance!!!
ed_texan
Texas
I do not have a schematic of the system yet, and I am not sure if the diagnostic test 46 bypasses the water reservoir and filter. Lastly, I replaced/reset the filter counter and no clog at filter.
All it says is: Service Test - 46 Water dispensing Test--->Displays the status of the water dispense valve. Press the water pad to initiate a water dispense. (00 = Water Dispense Valve Off, 01 = Water Dispense Valve On).
So in that test it shows 01 = Water Dispense Valve On when you press the water pad and water does flow out the water dispenser?
Usually if the TEST 46 works in diagnostic mode, but not regular mode then problem is the control board:
  • W10844356-RevA.pdf
ed_texan
Texas
Thanks Jake. Yes, test 46 does exactly as you stated, and the indications 00 or 01 do change as I activate and release the dispenser control.
I guess my question now is the control board is used in both normal and diagnostic operations, correct?
Either way, I gotta open it up and check it out. Now I guess I will try and locate this board!!!
Regards,
Yes it is.
Pull the refrigerator out from the wall, then you will see a cover on the back exterior wall, underneath that cover are the control boards, the MIDDLE(LARGER) one is the main control board.
mojo
Maryland
Regards,
We are having the same issue. Did a new control board work? This fridge has been nothing but trouble!
