mspeed05
- KRMF706ESS01
- KitchenAid
- 1-5 years
I have read several posts about similar issues with this model freezing up the evaporator coil in the freezer. I have followed all the tips and checks from those posts. Service test 6 checks out ok. Left it engaged on result 3 and defroster is definitely working. Fan was running (making noise when fan was hitting ice). Service test 38 engages defrost with Sh option. Evap thermistor test had 01 pass. I saw where someone had an issue with the drain being clogged. I removed the drain line from the rear and ensured it was open, but as I have been defrosting there is no water going to the pan underneath. Assuming the line inside is clogged. Could that be causing the evaporator coil to frost over?
