KRMF706ESS01 KitchenAid Refrigerator Making Loud Buzzing Sound
TEST 77 should test the defrost thermistor properly based on temperature.
Per the tech data sheet--->You can check the voltage to it on the main control board--->FC Defrost Thermistor Output--->P8-1 to P8-2 should read 5 Volts DC when you have it in TEST 77.
I could not locate the service manual for this model.
Also per the tech. data sheet it should read 2700 ohms at 77 degrees F and 7964 ohms at 36 degrees F.
