KRMF706ESS01 KitchenAid Refrigerator not cooling (freezer working fine)
srrepaka
KRMF706ESS01
Our refrigerator Kitchen Aid KRMF706ESS01 is not cooling. I tested the temperature and it's around 59 F but the freezer seems to be fine. I tried to look upon how to diagnose the problem but could not. I really appreciate any help.
thanks.
Do you hear the FRESH FOOD EVAPORATOR FAN MOTOR running in your refrigerator section?
If not: Then pull your refrigerator out from the wall and remove the cover over the main control board, then on the main control board P14-3(YELLOW) and P14-4(RED) are the wires to the R(refrigerator)C(compartment) EVAP FAN MOTOR. If you are getting 12.7 Volts DC then your problem is the FRESH FOOD EVAPORATOR FAN MOTOR.
Here's the FRESH FOOD EVAPORATOR FAN MOTOR for your model you can order:
Evaporator Fan Motor W11087438
To access it: Look at page 5-9 and 5-10 here: https://www.dropbox.com/s/s5wx9d9xppw3wry/R-114 JOB AID W10444924.pdf?dl=0
It will show you how, you may have to remove the Air Tower and the Deli Drawer first, Deli Drawer removal is on 5-7 and 5-8.
Tahir
Usa
Hi Jake, I removed the connector from the board and checked the voltage on the board pins (3 and 4). It’s not showing anything. Please help.
Chris107
St. Louis
Ive had a similar problem. Mine was icing up then wouldn’t cool below 45. I replaced the evaporator fan motor W11087438. Still wont go below 40 to 45 degrees. Freezer is working fine.
any help would be appreciated. Thanks
Hi Chris, do you have the exact same model number KRMF706ESS01 ?
The model number tag is located inside the refrigerator section on the upper walls or ceiling.
Chris107
St. Louis
Yes sorry same model. Fan runs coil temp will get down to 19 degrees If you select max cold. Just doesn’t seem like it runs long enough. Ran it through the diagnostics and passed all the test
thanks
Then you will need to replace the main control board I posted the link to in post #4 above.
