KRMF706ESS01 KitchenAid Refrigerator top lights out
ToddD89
Georgia, USA
KRMF706ESS01
Hello. Refrigerator is right at 2 years old. Last week all 5 LED's in the ceiling of the refrigerator went out. All others are still lit fully bright. Any recommendations on what to look for? Could it be one bad LED fixture? Assume it isn't a module since the other LED's are still lit. Thanks in advance.
Hi Todd,
Ok, on your model the freezer LED module controls the top refrigerator LED modules, they are in series.
Open the freezer door and see if the freezer LED light comes on, if not you will need to replace the freezer LED module and the rest of the top refrigerator LED lights will start working as well.
Here's the freezer LED module for your model you can order:
W10695459 Module
This video gives you the general idea of how to replace it:
Let us know.
Your welcome Todd.
Did the freezer LED light come on when you opened the freezer door?
ToddD89
Georgia, USA
Not at home yet to confirm, but pretty sure it does not. So it should just be replacing that light, right? Will check tonight.
Yes, if that freezer LED light does not come on, then replacing that one will make them all work again.:)
Payson, Utah
So I have the same exact problem yet with a Whirlpool WRF767SDHZ00.
I saw the other posts and then came across this one. (The others are closed).
My freezer light and the top three are out. So, bought the new board. Put it in the freezer and still the same problem. So, either my replacement part was bad......or I have something else going on. Any suggestions? I thought I about just ordering another replacement but thought I would ask first.
Ok, one way to find out is to jump the TWO wires that connect to the FREEZER LED and see if the top 3 in the refrigerator section come on again, if so, then we definitely know that FREEER LED is bad that you got.
Your model uses the exact same FREEZER LED:
W10695459 Module
A jumper needs to be placed across the 2 connection points on the potentially failed LED module. See Figure 3. The refrigerator must then be plugged back in to identify if the jumper makes the remaining lights come back on. If it does, then that would indicate the LED has failed and would need to be replaced, otherwise you will need to repeat the process for each potentially failed LED module.
Let us know what happens.
Megan1
Dallas, Tx
Hi Todd,
W10695459 Module
Let us know.
Hi, I have this same problem. I just got the part in, but how do I know which led in my freezer to pull out and replace? My model number is KRFF507HPS00
The freezer LED light that is not ON when the freezer door is open.
