mmaloneyx2
- KRMF706ESS01
- KitchenAid
- 1-5 years
All,
I have an issue with my Kitchen Aid, French Door, 5 Door Refrigerator that I bought used. The main problem is that water is not dispensing. I have had this problem since day one. Later I had issues with lights and door display and found that it was a fault with the Pantry UI. After unplugging the pantry UI (with help from this forum) the lights and door display began working again.
However, all through this time I have had water dispenser issues. At first it did not work. Upon changing the filter it began to very slowly dispense water a day later. Upon trying to flush the filter with 2 gallons of water, the dispenser stopped working all together.
I have not tested any valves yet for voltage/ohms, but I suspect it to be W10865826 or WPW10341329 if a valve is at fault. Can anyone provide some insight here? There is no issues with water supply. Thanks.
