FIXED KRSC503 KitchenAid Refrigerator - Water dispensing when pushing Ice paddle
lakeside
Willis TX
KRSC503
Water dispenses (from the water dispenser) when first pushing the ice paddle. Re-pushing the ice paddle dispenses ice correctly. I have tried disconnecting power and turning off the ice maker. Anything I can do myself?
Mcpatty
Venice, FL
We have the same problem. Had the Dispensing board replaced, but sadly that did not fix the problem. The technician said we needed to either replace both paddles for about $250 plus labor or replace the circuit for about $300, plus labor. Since he didn’t know which one would fix the problem we decided not to do either. You are the first person I’ve been able to find on the Internet that has the same problem. We called KitchenAid and they said they never heard of it and they were no use. So now we are living with it by first pressing the water paddle for few seconds with our cup underneath it and then pressing the ice paddle, which now will dispense only ice.
Usually it's just the paddle that you need, what is your complete model number of your refrigerator? The model number tag is located inside the refrigerator section on the upper walls or ceiling.
Does your model have 1 paddle for both the ice and water? Or 2 paddles for each ice and water?
Sorry @lakeside we must of missed your thread back in June.
KRSC503ESS00 shows only one paddle for both ice and water.
Please take a photo of your model number tag and your two paddles.
#12 is the only paddle it shows.
Mcpatty
Venice, FL
There are the pics you requested.
Ok, That is very strange.
What did the tech say to why there is only one paddle showing on the parts diagram?
Did he find BOTH paddle part numbers? If so, we need those part numbers. If he didn't say, please call him and ask him.
Mcpatty
Venice, FL
The tech that came out said the problem could either be solved by two new paddles or a new circuit board. I cannot spend that. Ugh money on a “maybe” answer. i just spend $300 on a whole new freezer door about a year ago ( paid for labor only) and now this problem. This refrigerator is a piece of crap! Unless I hear a definitive answer that will solve this problem, I will not spend another penny on it.
Mcpatty
Venice, FL
The tech did not look at a diagram of it. He said he looked up the cost of the paddles and they were about $125 each.
Piperco
Miami, FL
Hi! I know this thread is a few months old. I am having the same issue on my refrigerator as well. Has anyone found a resolution to the problem?
Appreciate the help!
Evan
greenurry
Florida
Fortunately this happened while still under warranty. When I spoke to the repair company the technician knew exactly what was wrong and ordered both new paddles. He said they short out, and replaced both in case there was a defect in the water dispenser as well. Took off the dispenser panel, replaced both paddles and reassembled. Took 10 minutes. You don't HAVE to replace both, he just did since there was no cost to me and didn't want me to have a problem with the other paddle later.
davidpwalther
Madison, Wisconsin
I had the same problem of a bit of water coming out of the water dispenser when pressed the ice pad first. What stopped it for me was doing a "Measured Fill" located on the taskbar far right . Since using that function for one glass and waiting until it cleared the screen, I can hit the ice pad first without water coming out of the water dispenser. I have a Kitchen Aid KRSC503ESS.
Mcpatty
Venice, FL
Are you saying that the problem stopped altogether or it stopped because before you press the ice paddle, you press the water paddle first every time? That is what we do now. I don’t want to spend any more money fixing this POS!
davidpwalther
Madison, Wisconsin
I know what your saying because I used to do that prior to ice, but for the time being it works to run through the measured fill just one time. then if you want ice use the usual pad press for ice first and then the water without water running a little bit also when you press ice first. I only did the measured fill one time separately.
Mcpatty
Venice, FL
What do mean by running through the measured fill exactly? I always get water by the measured feature
Randogg
Houston
We have exactly this same problem. The tech said it's the paddle switches and that you can "clean" them and they will work for a while or replace them and they will work for a few years.
I've tried to get the paddles and touch screen off but can't figure it out and I haven't found it on youtube yet.
Anyone know how to get to the paddle switches?
Hi Ran,
We need the model number of your refrigerator, the model number tag is located inside the refrigerator section on the upper walls or ceiling.
Randogg
Houston
Hi Jake,
My model is the same as the above, MOD.: KRSC503ESS00. Serial number is SER.: HR61108908.
Regards,
Randy
