KRSC503ESS01 KitchenAid Refrigerator - Freezer door broken wires
AZrobotech
Buckeye, AZ
KRSC503ESS01
Welp after lots of searching and worry I found that my freezer has the broken wire harness issue that takes the ice maker out.
I've only had my fridge for about two years. Has anyone had any luck with KitchenAid replacing the door?
Quite a few members have repaired the wires. This seems to be a common issue as of late.
Yes, Rick is right this happen been a ongoing problem for awhile now with KitchenAid and Whirlpool side by side refrigerators.
Most solder the wires back together, if you need more slack add some extra wire to the broken and frayed ones. Most all hardware stores sell electrical wire.
