KSC23C8EYY03 Refigerator side 42 degrees
Gatormike
Albuquerque, NM
KSC23C8EYY03
OK, so the refrigerator side only gets to about 44 degrees. Lot of ice built up at back of bottom draw. Condenser coils underneath look good and are clean. Compressor hot to touch. Condenser fan working. Removed plastic panel behind lower drawers in fridge and found large chunk of styrofoam. Is this covering coils that may be froze up ? Can hear what I think is fan running when open fridge door. Freezer appears to be working fine. Any suggestions will be greatly appreciated.
Your machine has dual evaporators. The one in the fresh food section doesn't use a defrost heater. Instead, it self defrosts each time it cycles off. Remove the evaporator cover and evaporator insulation the fan motor is located inside the styrofoam insulation Check if the coils are frosted over. I'll need to find the tech sheet and wiring diagram for that particular model. See if you can locate yours. Here's a diagram of the most common places.
Gatormike
Albuquerque, NM
No spec sheet found, Curious as to what this plastic tubing is for in the back of fridge. Still working on finding a hair dryer to try to remove styrofoam piece. Thanks
The 6 switches along the bottom of the display are #1 to #6.
To enter Service Diagnostics:
Press SW1 and SW2 simultaneously for 3 seconds.
Release both buttons when you hear the CHIME indicator.
Unit must not be in Lockout prior to entering SERVICE DIAGNOSTIC MODE.
The display will show 01 to indicate the control is in test 1 of the diagnostics routine.
To exit Service Diagnostics
Press SW1 and SW2 simultaneously for 3 seconds, disconnect the product from power or wait 20 minutes.
Following the exit of the diagnostic mode, the controls will then resume normal operation.
Each test must be manually advanced.
Press SW5 to move to the next test in the sequence.
Press SW4 to back up in the sequence to the previous test.
Diagnostics begins with Test 01.
Each step is displayed in the two digits of the dispenser user interface display.
The step results are displayed in the two digits on dispenser user interface display 2 seconds after the step number is displayed.
An amber order filter light will be shown to designate that the step number is being displayed
A red replace filter light will be shown to designate that the status of the step is being displayed.
Run Tests 1- 2- and 3.
43534
