a914nut
- KSC24C8EYY04
- KitchenAid
- 6-10 years
Hello and thank you for this valuable resource and all the advice given.
Bottom Line up front - I think I should replace the "main" board on my 2015 KitchenAid fridge/freezer, though I'm not sure which to buy...below are details, other suggestions appreciated.
My KitchenAid fridge has been driving me nuts for almost a year now.
ICE MAKER JAMMED: First, the icemaker kept getting jammed while ejecting the ice. I replaced it about 8-9 months ago and the new one was working well.
FRIDGE NOT COOLING RELIABLY: Then about 3 months after ice maker replacement, found contents of fridge not cold. Research here....Used on-board testing procedures...all appear to pass. Replaced fridge thermistor (cheap, easy so why not), installed snuggly and made sure correct location as per docs found here. Cooling improved for a short while, but would often find the fridge at 50F some days...and at 35F other days. Fridge circulator fan passes test, but seems to not blow very hard. Replaced fan (cheap easy so why not). No change in fan performance after replacement. Observed standing water under fridge evap coils every time I've taken the cover off during all this.
Cleaned coils under fridge as well.
So no real change from fan, thermistor or cleaning, but after a few days, the fridge seemed relatively stable so long as I don't turn the temp down below the "recommended" temp on the control panel. If I turn temp down more, seems as though evap coils freeze which shuts down cooling to allow to thaw (I assume) and then temps creep back to 40F-50F range. This has been the case now
MAX COOL and MAX ICE features do not work. If I turn them on nothing happens.
FREEZER NOT COLD ENOUGH and NO MORE ICE: Now in last month, freezer will maintain 20-30F keeping most thinks frozen, but not cool enough to reliably freeze unfrozen foods within 12-18 hours. Like the fridge, freezer evap fan seems to only operate at low speeds. If I put store bought ice in the ice dispenser bucket, the ice will stay frozen...but ice maker will not make ice but for once or twice every 2-3 days!
Based on my totally unexperienced guess, I 'think' that because the control board is only operating the fridge and freezer fans at their lowest speeds, that both coils will start to freeze triggering defrost modes too frequently and causing the anemic cooling performance on both sides.
Thoughts?
Thoughts?
