KSRP25SSS01 KitchenAid Refrigerator Wiring diagram
Mcnabb75
Greenville SC
KSRP25SSS01
Hey there,
Trying to figure out why the ice dispenser auger is not working. No tech manual with the fridge so I am not sure what wires to check off the board to see if it is getting power.
Anyone have a wiring diagram?
Thank you.
The dispenser control has a built-in inverter that converts 120 VAC to 120 VDC. Connect your meter to the BRN/WHT wire and the RED/WHT wire on the auger motor. Depending on the cube/crushed selection, your meter should indicate either +120 VDC or -120 VDC
