- KSSC42QMS01
- KitchenAid
- More than 10 years
I need to test and possibly replace the inlet valve on my KitchenAid built in. The valve is located underneath and there is no room to get to it.
Do I lay down a 650lb fridge on it's side? Do I crank up the leveling feet to the max, how much room will that give me? Right now I barely have 5" of space. It's hard to see the valve, let alone remove it.
Ice maker is working.
I was able to remove the tube going into the filter, and it's clear from there.
I removed and replaced the filter, tried a new filter.
I get the "click" from the micro switch in the door, and the light does come on.
The hum/buzz you normally hear when water is dispensing is no longer there.
The water stopped dispensing while in use.
Any thoughts? I'm fairly certain it's the valve.
