- KSSC48QVS03
- KitchenAid
- 6-10 years
Hello,
I want to thank you in advance to anyone who can shed some light on this.
I have a fridge (KitchenAid model KSSC48QVS03) that has been working good for one (1) year. The appliance was in the house when I moved and I suppose has not been repair before.
We went out during four (4) weeks and unplugged the refrigerator in order to save energy and perform a deep clean after coming back. The condenser was clean due to some dust as the interior.
After plugged in and running for 24h it is not cooling the fridge and freezer. I unplugged the unit, wait for one (1) hour and plugged it back in, and same situation.
The energy consumption device shows a current of ~0.64A with a peak of ~2A when turn the unit. Additionally, during June and after plugged, the consumption (by day) is show in the following pictures:
Both graphs show a base consumption around ~0.65A.
I disassembly the unit and perform the following evaluations:
The results are as below:
Below some images of the refrigerators.
I'm following the user manual "TECHNICAL EDUCATION, KAR-11, JOB AID 4317326A, 2001 K MODEL BUILT-IN SIDE-BY-SIDE REFRIGERATOR WITH VARIABLE CAPACITY COMPRESSOR".
I have no more options than to evaluate to understand where the problem is.
Any advise would be greatly appreciated!
Thanks, Hu
June (working normally) | August (after unplugged during July) |
- Compressor. It seem working. I can feel the vibration and is hot (I still can touch indefinitely without burning). All the pipes are neither hot or cold.
- Condenser. The pipes temperature is same as the environment.
- Condenser fan. Its working (visual inspection).
- Evaporator. The coils seems good.
- Evaporator fan. Its working (visual inspection).
- Defrost pipe. The temperature is same as the environment.
- Air door (between freezer and fridge). Its working (visual inspection).
- Thermistors. The impedance is around 2.4K ohm, matching the specifications at environment temperature (~25 degree Celsius).
- Diagnostics. Pressing buttons MAX COOLING and ON/OFF at the same time for 3 seconds, allows to perform following tastings:
Test | Result |
Freezer thermistor | "01" normal range |
Refrigerator thermistor" | "01" normal range |
Evaporator fan motor | "--" the fan started and stopped ok. The results doesn't match with any of the table. Perhaps, a different model/number |
Condenser fan motor | "--" the fan started and stopped ok. The results doesn't match with any of the table. Perhaps, a different model/number |
Compressor | Shows "02" and after some time (minutes) it turn on and shows "01" indefinitely (25 minutes and later the diagnostic is stopped) |
Air door | "01" the door open and close (visual inspection) |
Bimetal/defrost heater | "02" bimetal open |
Evaporator | Evaporator thermal image (temperature around 28 and 31 degree Celsius). Nothing hot neither cold. |
Condenser unit | Compressor |
Control panel. The led (over temperature) and temperature numbers "21" are blinking. | Condenser coil |
I will attached more picture in next message (maximum 10 pictures) |
Thanks, Hu
