KSSO48FTX20 KitchenAid Refrigerator - Ice Bin slowly becomes a clump
RyaninAZ
Phoenix, AZ
KSSO48FTX20
Hello,
The ice bin in my Kitchenaid KSSO48FTX20 slowly turns into a clump which forms in the back left corner and slowly grows turning the bin into one large clump over the course of several months. I tried changing the freezer temp and even removing the light bulb directly below the ice bin and neither of those solved the issue. I'm guessing I have a very slow leak as the clump starts small and continually grows larger. I have watched the ice maker during the dump and fill cycle and I don't see any water dripping out nor do I see any icicles hanging from the ice maker. The unit otherwise works fine except for filling the bin a little higher than I'd like which causes some cubes to fall out when the bin is full.
I searched around and saw a thread about the water inlet valve being replaceable. I'm not sure if this is my issue or not so I thought it would be best to post a thread.
Thanks for the help!
Sounds like the water valve. Is there any ice in the fill tube?
The fill tube is behind the ice maker and sits in the fill cup on the ice maker. Use a good flashlight. You might need to remove the ice maker.
RyaninAZ
Phoenix, AZ
Okay I think I got a few good shots of it. Only appears to be one small piece of ice the on the left side. Looks pretty clean otherwise.
I do notice frost buildup behind the bin. Is this normal?
It's too hard to see inside the tube itself. The frost doesn't look normal. Your pic is too close. Is that the evaporator cover?
RyaninAZ
Phoenix, AZ
I'll probably need to remove the ice maker to see inside the tube more.
Here are some better pics of the frost. It's behind the ice bin which is about the middle of the freezer section. Could this be related to the ice forming into a block?
That looks like a defrost issue. Are you having any cooling issues? Does that frost go all the way to the bottom?
RyaninAZ
Phoenix, AZ
I haven't noticed any problems with cooling. Sometimes the actual temp will drop about 4 or 5 degrees below the set temp for a short period of time, but I assumed that was just normal from the compressor going into high operation.
The frost goes a little below the ice bin. You can see some in the section right below it. But it doesn't go all the way to the bottom. There nothing in the next "section" below.
That's right where the fan motor is. The fan motor could be causing both problems. Sometimes when they wear out the motor starts running hot. See if the fan motor is covered with frost.
RyaninAZ
Phoenix, AZ
Do I just remove these screws and panel to check the motor?
RyaninAZ
Phoenix, AZ
I didn't remove the panel completely but pulling it back I was able to see the fan blades. I don't see any frost.
Most of the frost is just above this area where the fan is. Should I remove the panel directly behind the ice bin and see what's there?
It's just an air channel. I've never seen that before and if it's warm air, it's probably why the ice clumps. Look in the dispenser and see if the ice door is closing all the way. That would make sense and explain the frost and ice cubes sticking.
So much for that idea...Lol Let me look at the service information on that model and I'll see what I can come up with.
Force the ice maker into a harvest cycle. Use your flashlight and check the ice maker operation. Let's make sure the heater isn't sticking on. At the end of the harvest cycle is the fill cycle. Make sure there's no splashing or dripping or overfilling. To force cycle the ice maker, remove the cover over the ice maker power module and locate holes "T" and "H". Use a short piece of insulated wire bent in the shape of a U and short holes "T"and "H". As soon as the white gear starts to turn remove the wire. You may need to hold the door switch closed.
RyaninAZ
Phoenix, AZ
Thanks Rick. I'm going to be gone most of the day for thanksgiving. I will run this test Friday and see what happens. I can video the harvest cycle to check for overfill, splashing or dripping. As for the heater sticking on, how would I check for this?
The heater is on the bottom of the ice maker. It's only on for a short time, until the ejector reaches the 7 o'clock position. After the harvest cycle and after the fill cycle the heater should be cool.
