KSSS36QTB03 Kitchenaid Side by Side Need help wiring the Ice Auger Motor
alekov
Naples
KSSS36QTB03
Need help wiring a new Ice Auger on a built in Kitchen Aid KSSS36qtb03. Unfortunately the wires are out of the plastic plug part as they are old and broken. I'm including pictures, 4 wires Black, Red, Blue, and Grey. Unfortunately the Auger doesn't seem to be exact fit as far as wiring plug goes, since the pins seem to be in a different position. The auger itself fits exact in the place where it's supposed to. My plan is to use an individual wire clamps for each of the 4 pins so I can attach the right wire to each pin. Any help would be greatly appreciated as I am not exactly sure which wire goes where on the pins of the Auger... Looked around the net for wiring diagram, but to no avail..
alekov
Naples
Thank you so much. Is that the order I use to wire in the above Ice Auger though? Starting at the left pin facing the ice auger the way it is pictured?
