Steve24
- KTRS21KDWH05
- KitchenAid
- More than 10 years
I've got an older Kitchenaid refrigerator, model KTRS21KDWH05. It still works quite well, gets cold, doesn't run the compressor constantly, and is clean. But when the compressor stops there's a shudder and a noise.
I took off the panel on the back that covers the compressor and let the thing run and shut off. A bit of a shudder but no noise. The compressor seems stable, doesn't move much when it stops and the compressor mounting feet are intact and seems strong. So I cleaned out all the dusk (yikes!) and put the cover back on. Noise reappears.
From this, I deduce that something is pressing into the panel. I think it's the thing that I've circled in red in the attached picture. You can see an impression of the thermostat sensor wire in the insulation attached to the back cover. So I know it's pressing against the cover. I think what's happening is that the pipe behind the object I circled vibrates when the compressor stops. And when the cover is on the vertical thermostat thing rattles against the pipe and generates the noise.
I'm afraid to bend anything for fear of creating a coolant leak, but I don't think I would need to bend anything very far.
Does anybody have any suggestions? Am on on the right track or am missing something?
Thanks very much for any light you can shed.
