KUDS01ILBT6 KitchenAid Dishwasher fills with water then stops
DanY123
MI
KUDS01ILBT6
I've had this happen twice that I know of where the dishwasher will fill with water then does not continue on. It happened once when it filled with water after the first rinse cycle, it filled with water, I could hear the soap dispenser open then nothing. It happened again on the last fill in the Baked on Cookware cycle, it filled then stopped. I got it to start again after I opened and shut the door. The lights on the control panel are lit while this is going on. I replaced the circulation pump and assembly in May of 2018 (Part # W10782773). Any help would be appreciated. Thanks
Hi Dan,
I'd first check your motor capacitor. See if its bulged at the top of it. If not, you can still test it, there is a capacitor testing video in the part link to it below.
Here's the motor capacitor for your model:
Capacitor WPW10334457
If the motor capacitor is fine, then check for 120 volts at the BLUE wire and VIOLET wire to the sump wash motor after it fills and should be running, if your meter says 120 volts to it and its not running its bad.
Here's the sump motor for your model:
Circulation Pump Motor WPW10757217
Here's the video to access/replace it:
DanY123
MI
OK, I'll try that. Interesting to note that if I order the whole motor & pump assembly its about $50 cheaper than just the motor. Am I missing anything?
Dan
Yes Dan, you are correct, getting the complete wash motor/sump assembly is much less expensive than the wash motor alone.
Here it is for your model:
W10782773 PUMP&MOTOR
DanY123
MI
Hi Jake, sorry to leave this tread hanging but the washer has been working fine up until now but I have noticed something recently. I usually use the 'baked on cookware' cycle and that seems to be working fine. I tried the normal cycle and the motor would not start after it filled with water after it drained during the cycle. Ran it on the 'baked on cookware' cycle after that and it ran fine and I have been using that cycle since. Does that still point to the motor as the problem? I have not tried testing the voltage at the motor since the problem has been intermittent. Thanks
Dan
That's the only way you will know Dan, when the wash motor does not run on the NORMAL cycle.:)
DanY123
MI
I took off the bottom cover to access the wires and I don't see how I'm going to get to the wires on the motor while its running. I think I may just roll the dice and get a new motor.
You'd need to pull the dishwasher out a little bit to get to those wires.
But on this model if the wash motor is running on the 'baked on cookware' cycle, then the motor should be fine. So it would seem to me to be the control board not sending 120 volts to the motor in the "NORMAL" cycle.
Here's the control board for your model: WP8564543
Buts its been discontinued. 🙁
DanY123
MI
Do those wires come from the control board? Is it possible to test them at the control board?
Yes,
Volt test across P5(Blue wire) and P9(Red/Black wire). Make sure the door switch is closed or bypassed when you do that.
I'm attaching your tech data sheet below.
  • 8564549.pdf
