t126b
- KUDS25SHWH1
- KitchenAid
- More than 10 years
Hi everyone ... this is my first post. After I replaced the motor and pump assembly on my KitchenAid Superba Whisper Quiet Ultima Dishwasher model KUDS25SHWH1 that stopped the leak, but I finally noticed the bottom spray arm is striking the bottom of the lower rack. In fact, I don't think the spray arm is rotating! I say finally because it was months <sigh> after I did the ($300) replacement that I noticed the arm was not free to rotate ... so I cannot get the part replaced under warranty.
Does anyone have a suggestion about anything I can adjust to allow the lower spray arm to rotate?
The weird thing is ... The motor and pump assembly fit perfectly in the dishwasher! There is a drop in fit with tabs to rotate to keep the motor in place plus all the connections are all as expected, power and water. The only difference between the old and new assemblies is the new one has no need of a counterweight. I cannot figure out how the new assembly could be mounted too high because it is secure and not leaking. The course filter around the assembly looks to be sitting in the proper position too!
I (more than) double checked the part number and it was right. Yet, the lower spray arm is too high; it is frustrating.
Here are photos of the installed motor and pump assembly and the obvious damage to the spray arm.
Thank you for your help!
