KUDS30CXSS0 Heating problems
Jeffhalljr
Atlanta ga
KUDS30CXSS0
After running the washer diagnostics I am receiving a 7-1, 6-2, and 3-3 fault codes. I went ahead and ordered a replacement heating element from sears parts direct.
After installing the heating element, running the diagnostic cycle, and running a complete cycle that did not appear to work. I had also purchased a replacement thermostat just Incase. I went through the same process and that did not fix the issue either.
I tested the new heating element and it read 0 ohms which caused me to doubt the element was good. I promptly received a replacement element from the supplier. When it arrived it also read 0 ohms. To double check I was not crazy I have watched several videos online to make sure I was measuring correctly and indeed should get something other than 0 or 1 (which I confirmed). Any thoughts?
By the way I also measured the old heating element and it read .78 ohms and the old and new thermostat read 0 ohms.
To address the 3-3 code I removed the Turbidity sensor, cleaned it and reinstalled it. Once I ran the diagnostic cycle again it did not clear the code.
If you have some ideas on the above and next steps I would appreciate it.
Tyler H
Alberta
I am starting down this same path. The element won't heat. I checked the thermostat. Seems to have continuity.
Jeffhalljr
Atlanta ga
For further context to my origional post please see the below pictures.
Multimeter settings
Old vs New Thermostat
Old VS New Heating Element
You have your meter set way too high at 2 million ohms, it needs to be set at 200 ohms.:)
Put the meter at 200 ohms then ohm test it.:)
Jeffhalljr
Atlanta ga
Next Step - Control Board
After using my multimeter correctly I have moved on to the control board...
I noticed that there are heat marks in the power input, heating element, thermal fuse input. See pictures below. I did test the thermal fuse and it reads 0 ohms. I also tested the wiring and it seems ok as well.
Is there a way to test the board or do I just get a replacement?
Connector
Back of the control board
Yes, 13.5 ohms is much better.:)
Yuppers, your control board is the problem, I clearly see the burnt spots on it. You need to replace it.
WPW10380685 Electronic Control Board
You get $60 cash back on your credit card when you return your old control board.:)
Total price with CASH BACK is $103.63
