ChadW
- KUDS35FXSS8
- KitchenAid
- 6-10 years
I have the KitchenAid dishwasher model KUDS35FXSS8. One moment, I'm pushing the buttons and things are working and the next, the lights went off and it's completely unresponsive. Unplugging the dishwasher and plugging it back in did not correct the issue. I took the door panel off and looked at the control board. I did not find any visible burn marks on the wiring and tested the voltage coming into the board (at the connectors) to be 120V. I read somewhere that unplugging the control panel from the board and power cycling the unit, followed by closing the door after 10 seconds should turn on the pump (as a diagnostic test). However, after following those directions, my pump did not turn on. I'm uncertain though if that test is valid for my model.
Before I purchase a new control board, is there a more positive way to know if that's the part I need to fix my problem?
