- KUIA18NNJS11
- KitchenAid
- More than 10 years
I am usually able to repair this machine but this time I am stumped. When I turn the machine on it always performs the flush cycle as it should but, after the 2nd fill when the freeze mode begins, the recirculation pump runs for about 30 seconds and then shuts down. The condenser fan continues to run and the evaporator plate still continues to freeze, just no water pumping.
I am checking the voltage at the pump plug on the bracket in the interior of the machine and the voltage is dropping from 14v to around 10v-11v shortly after it initializes the recirculation pump. I am assuming this drop in voltage is what is causing the pump to stop if it truly needs at least 12v to operate.
If this drop in voltage is not normal would the issue most likely be the transformer, board, or harness? or is the drop in voltage normal?
Thanks for the help!
Terry
Terry
