KUIC15PLTS1 compressor starts then stops about 15s later
jm_maclaren
New Orleans
KUIC15PLTS1
My KUIC15PLTS1 ice maker is again being difficult. The compressor starts and then stops abut 15 s later. The evaporator plate gets cold but not cold enough to freeze water and hence no ice, grr. It looks like teen has been some leaking and corrosion. Is this symptom likely due to low refrigerant levels of or from something else. I am assuming I would need a repair man to refill and/or check for leaks. Any help apreciated. Thanks
James
Sounds like either the start device or compressor is the problem. Measure the resistance of compressor windings:
Check the start device. Relay should measure 3-23Ω. The overload should measure less than 1Ω
jm_maclaren
New Orleans
Windings on the compressor tested fine. I replaced the start device with a supco RCO810 and it seems to be fixed and making ice again. Hopefully that was the issue! Thanks for your help.
James
jm_maclaren
New Orleans
Yikes, thanks for the warning. I have turned it off for now. How do I bypass the start capacitor on it? I opened it up and some clipped wires came off. I assume the big capacitor is the start.
red is run white start and black common. Should the white connect to the upper circular part see pic?
jm_maclaren
New Orleans
other black wire which gets from supply to common appears to just be a loop in and out of the can without any connections
The start cap is inline with the start windings so take the wires off the start cap and short them together.
jm_maclaren
New Orleans
As I look at the circuit, I have bypassed the start capacitor and have 0.1ohm between one live wire and the run (red lead) and 4.8 ohm between that live wire and the start lead (white). So does the relay cut off the start somehow once running?
When the compressor circuit is first energized the relay has low resistance 3-12 ohms and both run and start windings are energized to start the compressor. When the self-heating relay has reached temperature it will change from low resistance 3-12 ohms to high resistance 10k-20k ohms and switches off the start windings.
jm_maclaren
New Orleans
Then the circuit makes sense. I have bypassed the capacitor and will put it back in the ice maker.
Am i safe to use it now?
Should be ok to use now. Is the Hp listed on the compressor? I think that's the right size.
jm_maclaren
New Orleans
I looked the model up it’s 1/5 hp and that part was for up to 1/5 hp
thanks for letting me know so quickly that it would damage the compressor and electronics with the capacitor inline. Much appreciated.
I was able to bypass the capacitor bonce I opened the canister.
would you recommend ordering the exact replacement part for the long term?
