KUIO18NNZS KitchenAid Stand Alone Ice Maker Not Working Properly
Dan M.
KUIO18NNZS
Hoping someone can help. Ice maker has been thoroughly cleaned inside and out. When I turn it on everything appears to be working properly and it produces a small ice sheet which ends up on the ice cutter. On the next ice producing cycle it stops working and the On/Off and Max Ice LED lights are blinking. Ran the manual diagnostics on tech sheet which suggests everything is working properly. The tech sheet says the two blinking lights indicate a harvest failure.
What is my next step?
Also, about how long should the ice cutter take to cut the ice sheet produced?
