KUWS24LSBS Wine Cellar Does Not Go Below 60F
Nero365
Raleigh
KUWS24LSBS
I have had this KUWS24LSBS Wine Cellar for two years and the past few months we have noticed that it does not go below 60F when on the coldest setting. It only has 4 bottles inside and wanted to see if anyone has had this issue. The fans still turn on and sounds like it is running fine. Is it the internal thermostat?
Thank you!
Make sure the base grill is clear and not blocking air flow. Make sure the condensor fan is working correctly. I understand you don't have anything to compare it with but it should be turning a pretty good clip. This style fan has had troubles with slowing down. Feel the compressor and see if it's warm or hot.
