LAFW8000LW0 Frigidaire affinity washer e35 code
Bmusgrove10
Louisiana
LAFW8000LW0
Frigidaire
So I recently acquired a frigidaire affinity washer and dryer. I knew the washer had problems, I just need to know what would be causing the e35 code.
So have seen online that is probably either the pressure switch or the water intake valve. I unplugged the washer while it was filling and it continued to fill. It does typically fill to over 4.5 inches as well. Does this mean the water intake valve needs to be replaced?
I have the tech. data sheet for your model: https://www.dropbox.com/s/8lhn85su52ohb7s/LAFW8000LW0.pdf?dl=0
E35 Pressure sensor indicates water overfill--->Refer to test (5).
Yes, you are correct.
Here's the water inlet valve for your model you can order if the water keeps coming in when the machine is unplugged from the wall outlet:
Water Inlet Valve 134637810
