fdominguez40
- LAT5000AAW
- Maytag
- More than 10 years
Hello,
So last night washer wouldn't fill tub. Tested inlet valve with direct current, both hot and cold work fine. Tested for 120V at the inlet valve in fill position, no current. Tested pressure switch by blowing down hose into tube, clear. Blew into pressure switch with knob in fill position and pulled out, pressure switch clicks and washer starts to agitate. When dial is moved to spin cycle, starts and works fine. So I think its the timer switch panel??? Can you help me to test for proper voltage, at both the timer switch and the hot and cold switches?? Here's a pic of my open control panel. I also have the electronics schematic if needed. Thanks very much!
