Glad to see all the recent activity on this thread for my very similar model GM Frigidaire. Gives me hope that I will be out of the woods soon. I have looked over most of the information and compared my hand drawn diagram to the more official ones here. As is common I had to replace the brittle wire insulation on my working fridge and now I am in a wiring harness quandry. When I plugged the firdge in after carefully trying to replace the wires under the cold box to the relay and compressor, I shorted out. My wiring up to the switch, light and thermostat seem intact and i haven't replaced it....yet. Here's the problem. The diagram shows 3 wires coming from the switch, light and thermostat in the cold box area. I have 4. In the diagram 1 wire doubles up on a terminal at the thermostat. In my situation I would guess that it is not doubling up on that thermostat terminal as I have 2 wires returning from the thermostat area of the fridge and 2 wires returing from the switch area. My guess is that the extra wire returing from the switch area which in the diagram doubled up on the thermostat after routing past the light would go to the Number 1 screw on the YT Relay (the bottom left). Now here's the kicker, I have continuity across all terminals, hence why my circuit blew when connecting to AC. Ugh. Thoughts on what to do to get this fridge cold again? First image is my new wiring, secong image was my wiring schematic before taking apart, third image was the original wiring before my new replacement.
