LDE4415ST LG Electric Double Oven power completely went out
Maherclan9
Longmont, CO
LDE4415ST
LG
Less than 1 year
Bought an LG Double Oven. It was an open box from Best Buy. Just after 3 months, we were using both ovens when the power completely went out. Repair tech thought it might be the motherboard. Checking parts list that appears to be the "pcb main assembly"? Anyone else have that issue? Is that an easy part to replace? Model LDE4415ST
Yes, but you should have a warranty on this from LG even if it is a open box.
Here's the main control board for your model: EBR80595301 Pcb Assembly,main
Lets see if Jesse responds here: LG Range Not Working - LDE4415ST
Or it could be that thermostat he posted the link to in his post #4 of that thread. You'd need to ohm it for continuity, make sure the breaker is off to your double oven first, and remove the wires from it.
Ok Jim, sounds good.
