LDF7551ST LG Dishwasher E1 Pump Issues
layers1
San Antonio, Texas
LDF7551ST
LG
I hava a LG Dishwasher Model #LDF7551ST, that works well and pumps the water out fine. After a few minutes of running, it will pump the water out again, probably like the third time, but the pump continues to run and the Error Code "E1" comes up. I have taken it out and hooked it up outside to make sure there were no issues with the lines kinked. Same results. You can unplug and plug it back in and the pump comes back on again. The water has all been pumped out.
Please help. Do I need a pump or is it something with a board or sensor?
Thank in advance,
Larry
Hi Larry,
Another member had this same error code here: FIXED: LG LDF7551ST E1 error code help
Our tech bigbuck assisted him with a couple of help links and he got it fixed.
See if those help links he posted helps you too.:)
Ok Larry sounds good.:)
