LEQ9858PW0 Whirlpool ultimate care II just stopped working.
Ericka65
Portland, OR
LEQ9858PW0
Hello,
Maybe someone can help. Dryer just wouldn't turn on nor does the light come on. Been having no issues just out of the blue. Also I checked and there is power to the dryer. I've been hearing about thermal switches going bad but would that effect the light?
-Ericka
A copy:
Q - My dryer is dead, what could do that ?
A- Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first.
Your dryer has one on the fan blower housing...
Thermal-Fuse-WP3392519-01993779.jpg Dryer thermal fuse located on the blower housing
[video=youtube_share;3nicyh6EUHc]https://youtu.be/3nicyh6EUHc[/video]
