lever-actuator DC66-00850A001
Val Aussie
Australia
WW10H8430EW/S
Samsung
Hi there, I desperately trying to find out the spot where to connect lever-actuator DC66-00850A001 (ring-ended) for the Samsung washer MODEL: WW10H8430EW/SA. I've changed the door lock EMZ Type881 Part number DC34-00026A and it is easy to understand how to connect lever-actuator DC66-00850A001 to the door lock. The other end of the lever-actuator has a ring shape and no visible connection point around the two pump assembly and surroundings. Please share any ideas or navigate me where to search. Thank you.
Hi Val,
Unfortunately, we don't have access to this model here in the USA.
You'll need to locate a appliance repair forum in Australia.
Some front-load washers have an emergency release for the door latch to open the door upon failure. Does that strap maybe just hang loose to be accessed in case of an emergency? Does pulling the strap unlatch the latch?
That's just a guess though.
Val Aussie
Australia
You are genius, Dan, that is right, it is a simple bypass to release the lock manually in case of malfunction, assuming that access can be available through the debris filter's hatch, without the need to remove the front panel. Thank you, mate!
