FIXED LFC25760SB - Interior Lights Issue
CheffyRedux
East Coast
LFC25760SB
LG
I'm having an issue with the interior lights of my LG LFC25760SB, manufactured in 2006. When the doors are opened, the interior lights do not come on.
We've tried a few things with no results:
  • Replaced bulbs with bulbs tested in another appliance
  • Replaced the light socket assembly
While troubleshooting, I've noticed that if the door is open and I repeatedly depress the door switch, the interior lights will flicker, so they are getting some power, they just won't remain on. I'm not sure what I should be looking for to further troubleshoot or what parts to replace, looking for some guidance from the community.
wildimaginations
Danville, California
Since your model is a french door model with 2 light switches, more than likely, the control board relay switch to the light bulbs has gone bad and the board will need to be replaced.
Its behind the refrigerator, you'll need to pull the refrigerator out from the wall, then unplug it, then you should see an access cover panel you remove to access it.
Its #500A here: parts for LG LFC25760SB - AppliancePartsPros.com
