- LFID2426TF1A
- Frigidaire
- 1-5 years
Hey all, we bought our house last year and in that time the dishwasher has been working great. Last night it wouldn't start (after running fine the previous day). There was water in the bottom so i assumed a clog. I drained the water out, removed all the parts in the bottom without finding much debris, I pulled the dishwasher out and disconnected the drain hose that goes to the disposal. I flushed water through that multiple times and did clear out some debris. I checked the rubber return flap and it seemed good. Reassembled, flipped the breaker back on, and still no luck.
As it sits the Normal Wash, Start/Cancel, and Delay Start lights are all on. None of the buttons are responsive to being pressed. When i hold the High Heat and Start/Cancel for 6 seconds, i think i hear a motor spool up for a brief second but thats it. I've taken the door cover off to inspect the latch, it seems to be functioning fine and the "plugs" that connect to it visibly looked fine. I've read to listen for two clicks, but all i hear is the one loud click of the latch bar snapping into place. From my reading it seems like this could be a door latch, touch pad, or control board problem. Like most, i'm on a budget and would rather not spend $250 replacing those items without some certainty. Any help would be appreciated.
Kyle
Kyle
